configure snmp delete trapreceiver
configure snmp delete trapreceiver [[ip_address | ipv6_address] {port_number} | all]
Description
Deletes a specified trap receiver or all authorized trap receivers.
Syntax Description
ip_address Specifies an SNMP trap receiver IPv4 address.
ipv6_address Specifies an SNMP trap receiver IPv6 address.
port_number Specifies the port associated with the receiver.
all Specifies all SNMP trap receiver IP addresses.
Default
The default port number is 162.
Usage Guidelines
Use this command to delete a trap receiver of the specified IPv4 or IPv6 address, or all authorized trap receivers.
This command deletes only the first SNMPv1/v2c trap receiver whose IP address and port number match the specified value.
The following command deletes the trap receiver 10.101.0.100 from the trap receiver list:
configure snmp delete trapreceiver 10.101.0.100
The following command deletes entries in the trap receiver list for 10.101.0.100, port 9990:
configure snmp delete trapreceiver 10.101.0.100 9990
Any entries for this IP address with a different community string will not be affected.
IPv6 support was added in ExtremeXOS 12.4.
Platform Availability
